Fillet not appearing
tom_19tom_19 Member Posts: 1
I'm filleting the external edges of an extruded flywheel rim, and the fillet doesn't seem to happen -- I see lines on the surfaces where the edge of the fillet would be, but no actual fillet. My design is here: https://cad.onshape.com/documents/079e9a76e80ba8037e7e51f8/w/d2a87564af757cde2f857041/e/ac1a3458879636e583ef8217
I'm sure I'm just doing something silly.
Incidentally, congratulations on how usable OnShape is on an iPhone 6 -- I would have expected a very frustrating experience on such a small screen, but the UI has been done very well.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    Edit Circular Pattern 3 and choose the Add option - currently you are creating 6 new parts, then only filleting one of them. You will have to edit the failed fillet and reselect the faces.
