[Bug] Linear part patterns not showing instances.
 roryaronson
                    Member Posts: 25 PRO
roryaronson
                    If I have a part in an assembly and linear pattern it to create five total instances, then the second one does not show up, so I only end up with the seed, #3, #4, and #5. If I linear patters to create only two instances, then the second one does show up. So this is only happening with patterns for 3+ instances.
EDIT: This link is now broken (see below)
EDIT: @roryaronson - this bug was found by our QA team and fixed yesterday, but not in time for the next update. It will be in the September update in about 3 weeks time. Thank you for your patience and sorry for the inconvenience.
