Fillet on boolean joins?
john_orr457john_orr457 Member Posts: 3
I have a complex shape created using a boolean subtract and cannot fillet the edges where the two original objects meet.  Is this expected behavior? Anyone know a work-around so I can fillet those edges?
  • Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 225 image
    John,
    Can you make your document public and share the link here? If not, maybe post a picture of the area in question.
    I would try making a 0.05" radius (or something small relative to your project) Fillet and seeing if that works.
    Let us know!
    Best,
    Jason
    Support & QA
  • john_orr457john_orr457 Member Posts: 3
    Sorry for the delay.  Here it is. I can get none of the corners in the j-hook areas of Part 1 to fillet.
    https://cad.onshape.com/documents/57b72797e4b0a399ffb0e5ce/w/07054ff6aeed87a2787ab818/e/94e556649d1624118154db22
    Yep!  That worked great! On to Shapeways!
