Fillet on boolean joins?
I have a complex shape created using a boolean subtract and cannot fillet the edges where the two original objects meet. Is this expected behavior? Anyone know a work-around so I can fillet those edges?
NeilCooke Moderator, Onshape Employees Posts: 5,838
The entities in Sketch 2 are not lined up causing a small step at the bottom of the J-hook. I would consider re-sketching one j-hook with only the outer profile (not overlapping geometry, with dimensions and correct constraints) - then use extrude remove (rather than extrude new and boolean subtract after) - then pattern the j-hook across the other side.Senior Director, Technical Services, EMEA5
Can you make your document public and share the link here? If not, maybe post a picture of the area in question.
I would try making a 0.05" radius (or something small relative to your project) Fillet and seeing if that works.
Let us know!
Best,
Jason
https://cad.onshape.com/documents/57b72797e4b0a399ffb0e5ce/w/07054ff6aeed87a2787ab818/e/94e556649d1624118154db22
