OnShape session times out too often...
Dylan_Stewart
                    Member, Developers Posts: 107 PRO
                    Is there a way to change the settings so this doesn't happen?
I'm working on a very tedious FS that's very long and if I make a mistake or need to go back, I can't.
Seems to happen about every 5 minutes or less....
Didn't this only happen if you left a document sitting for a long period of time without working in it?
Now I can be in the middle of working on a PS or FS or whatever and it'll time out thus taking away my ability to ctrl-z or undo....
Very very very irritating.
Digital Engineering
1
Can you please open a support ticket so we can add you to the active investigation? We will ask you some questions about your internet connection too.
Thanks and sorry for the hassle.
-John
Yes, I will get on that.
Thank you for the prompt response.
However, this morning I noticed very peculiar behavior that makes me think there is more going on.
I've been trying to edit a hole pattern by removing a sketch point from that pattern. I do that by right clicking the feature and selecting 'edit...'
In order to remove the hole from the sketch I either deselect that point by clicking it on the sketch or by clicking the x next to it in the list of sketch points in the edit dialog box.
As soon as I click on either the sketch point or the x, OnShape disconnects and I must reload. This has happened 5 times sequentially.
As a result I am no longer motivated to upgrade my internet connection until I am confident that OS has resolved other issues.
@Dylan_Stewart : have you noticed any trends this way?
@john_rousseau I submitted a trouble ticket.
Please check your network connection. If you are in a company or educational setting, talk to your IT administrator. If you are using a regular ISP, open a support ticket with them. Tell them that you are having frequent web socket disconnects.
-John
