I can't give dimension to a line, How can I fix this?
When I have to give a dimension to a line, I click the dimensions button and then the line I wan't to give a dimension to.
But then when I try to type in a number in the box the dimension doesn't change.
    Try refreshing and cache clear -> shift + F5 might do the trick.. If not, contact support through feedback in ?-menu.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,872
    Is the dimension grey? That means it is a "driven" dimension because your sketch is over defined. Only black dimensions can be modified.
  • rik_jansenrik_jansen Member Posts: 2
    I was indeed using internet explorer because it is the default browser where i was using it. Now that I'm using chrome I don't have the problem anymore. Thanks for the help.
