Importing .DWG or .DXF
alex_lototzky
alex_lototzky Member Posts: 5 ✭
edited September 2016 in Community Support
Hi, I have been in the migration phase of onshape testing out the feature and learning how to sketch and model. I like it.
Now I have started to bridge the gap between the archives and onshape and ran into the first speedhump.
I used Autocad 2011 (and 2016) and find that files, both .dxf and .dwg are not importing in any usefull way.
I found some threads in the forum about this that are dated 2015, and can only assume that this is still not fixed!
This is a rather major hole for me (and I imagine many others)
One of my major production partners also uses Autocad. I am yet to test an onshape exported file on them.
I have to say my confidence is shaken.
Is there a work around or is there feverish activity to plug this feature hole in onshape?
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,100 image
    both .dxf and .dwg are not importing in any useful way.
    Hi Alex, can you be a bit more specific? If you import a DXF or DWG it will create a drawing. If you want to build a 3D model of it, create a sketch and use the Import DWG/DXF button in sketch.
  • alex_lototzky
    Oh I feel like a fool. I have just watched the import DWG and DXF vids on Onshape on Youtube and its all clear now.
