Not possible to edit sketch dimensions
Hi!
I am trying to do my very first part. However, I am not able to edit the dimensions of the sketch at all. Dimensions are somehow locked immediately after the geometry is created.
Br, Niko
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    After you finish a sketch and create geometry with an extrude you can go back to the sketch to edit the dimensions by right-clicking on the sketch in the feature tree and selecting edit. From there you can change the dimensions and when you complete the sketch the geometry will update.
    Twitter: @bradleysauln
    edited September 2016
    +1 for using Chrome with Onshape
    (in Finnish) Jos tarvit apua suomeksi alkuun, niin laita yv.
  • niko_laukkanenniko_laukkanen Member Posts: 2
    Thanks...of course the browser was the issue...:P
  • rosie_tesmenitskayarosie_tesmenitskaya Member Posts: 1
    Sounds like your dimensions are being placed as Driven/Unlocked which means that the geometry is the driver. The underline means that you have just overriden the actual dimension value. Click on a dimension and look for a lock on the edit bar. Make sure it is shown as locked.
