How can I use profiles that are not user defined in the loft feature?
darren_13
Member, Developers Posts: 120 PRO
I created two profiles in my feature script and now I want these to be used in the loft feature, is there a way of using them? like profile is from sketch 1 at point (x,y)? or maybe someone could just direct me to a script that demos this if its easier?
Kind regards,
Darren Lynch
Kind regards,
Darren Lynch
NeilCooke
Moderator, Onshape Employees Posts: 6,008
The input needs to be a query so use qCreatedBy(id + "sketch1") and sketch2 in your arraySenior Director, Technical Services, EMEA5
opLoft(context, id + "loft1", {
"profileSubqueries" : SketchStore
I get, expect map found sketch? I have solved sketches 1 and 2 am I inputting the array correctly or does it need to be in a certain format?
Cheers, Darren
At least in my implementation, the above approach didn't quite work. I needed to add an entity type:
var SketchStore = [qCreatedBy(id + "sketch1", EntityType.FACE), qCreatedBy(id + "sketch2", EntityType.FACE)];
