Import procedures
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
Most of cad files I wan't to import are received by email or by some file share system. Neither of these channels are visible from import dialog so I need to first create local copy (and memorize this temp folder) and delete after import not to mess up with possible future versions.
Most of text / image / spreadsheet data I need to import comes in through clipboard (source web, emails). Same temp file story with these.
Request 1.
Support drag and drop import directly from email + file share viewers + local file system.
Request 2.
Support paste text / image / spreadsheet into tab directly from clipboard.
If you feel the same need, use feedback to join the request. (ticket: #38279)
I think the problem making them public is that same system is used for 'private' feedback which should remain between Onshape and customer..
I have put in tickets like, please add me to ???'s request about somestuff and had reply that it's been done. That's why I added the ticket number, to make it easier on the other end.
I'd love to have an extended "Derive" where you could choose from "Current Workspace", "Browse Documents" and additionally "Import from File"
I agree it'd be nice to import into current PS.
Owen S
ended in an improvement request: https://forum.onshape.com/discussion/4112/text-based-notes-tab-in-document#latest
perhaps you could give them an additional vote....
@lutz_niggl and owen, Instead of creating new tab for each file import, I would like to see 'imports' tab which would be like file explorer with all imported files on one tab. I know this messes up with current tab RMB functions but those functions could be transformed into RMB filename/icon menu.
I would still create separate doc for common parts but sometimes project has a lot of imports that should live in same doc.
I think I could do that. I've got some code that can parse dxf, and produces compact, fixed FS code with no tolerance issues into a single feature studio.
