Dimension from a point on a plane in a sketch to a different plane?
is there a way to create a dimension from a point to a plane like the height to a point in the z direction is 6" above the top plane? see the dotted blue line in the pic
NeilCooke Moderator, Onshape Employees Posts: 5,873
Hi @stewart_johnson - if the plane is not perpendicular to the sketch plane then your only option is to create a plane offset by the distance you want the point to be (before the sketch so you can reference it), then you can make the point coincident with the new plane.
Senior Director, Technical Services, EMEA5
