Copy/paste (move) an assembly tab
Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 267 ✭✭✭
edited September 2016 in Using Onshape
I like to extract a specific part studio (a lamp) and the assembly in which only this part is assembled from a document and move it to a new document.
l succeeded with the part studio by copy/pasting it. However there is not such a Copy to clipboard in the RMB context menu with the assembly tab.
How can I move this assembly to the new document?
    You need to make a copy of complete document and simply delete everything else.
    Or copy part studio (as you mentioned you succeeded) and recreate assembly in that new doc.
    I have requested for copy/paste/duplicate functions for assembly tab and I suppose there are also others with similar need. Maybe someday we will have also this function.
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    We can use one assembly from one document to other document by inserting that assembly as sub assembly.
  • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 267 ✭✭✭
    Narayan,
    I know, but do not like to use an assembly in another document but move it.
    The trick of 3dcad is a nice workaround I used successfully.
