Visual artifact or actual geometry?
Jlabs
Member Posts: 28 ✭✭
Im learning OnShape by recreating models I've previously made in Lightwave3d. Today I'm tackling a simple 6-sided dice model. It's one of the few models I've tried so far that is basically the same process in both apps: Intersect a sphere and a cube, fillet edges to smooth, make pips, profit. My problem is in onshape I've run into this:
Is this a rendering issue or has this actual geometry? My fillets did not fail and don't overlap, but they do come close to each other on all six sides. All sides are the same.
This looks like a graphical artifact, although it is hard to tell. If you are willing to post a public link, this will allow us to look closer to make sure.
