Intelligent copying possible?
 Josy_La
                    Member Posts: 82 ✭✭
Josy_La
                    Member Posts: 82 ✭✭
                    Does Onshape have a data management system or external app that could allow for intelligent copying similar to Autodesk Vault Copy-Design.
I was trying to create adaptable parts outside the copy command. We use shapes that have the same profile but with different lengths. This part is intelligent in a way that the length parameter is either table driven or by selecting a segment will match it's length. We insert the parent file then choose the appropriate occurrence to place in our assembly. I suppose FeatureScript could be used for that but this is not my specialty.
As far as copying a workspace is there a way to rename the parts automatically vs manually? Since we are always making a copy to meet other conditions; parts will follow a precise naming convention. We are looking for automatization to reduce risk of human errors.
