trying to remove the middle of concentric circles with extrude only removes the whole sketch
so i was trying to make a ball bearing assemble. i started my sketch with a circle, then made a second and used the concentric constraint. it aligned the circles as i wanted, gave them dimensions and all. however, when i used extrude to remove the middle section, the whole sketch would remove from the page. tried several ways till something worked, but was disappointed because something i thought should take 30 seconds to do took hours to finally make right. this was a few days ago so now i do not remember what i did to make it work, but it took a long time. i kind of likened it to the old paint program where you use the bucket feature to fill the color in, but if your bit map had a gap, the whole page would change color not the work you did. i seem to remember the circles were blue and not black, but nothing i did would make them black like they were "solid", kind of like a line and circle after a tangent constraint. what am i missing? thanks in advance for any help!
