Can anyone tell me how to draw this wheel.
rob_white
Member Posts: 15 ✭✭
mahir
Member, Developers Posts: 1,319 ✭✭✭✭✭
I see this being done in 4 features and 3 sketches.- Sketch the cross-section without ribs.
- Revolve to make the base wheel.
- On the same plane as the first sketch, sketch the rib.
- Extrude the rib symmetrically.
- Sketch the triangular cut.
- Extrude cut the triangle.
- Create a circular pattern of the rib and triangle extrudes.
5 -
rob_white
Member Posts: 15 ✭✭
Thanks to both of you, yes I am new to CAD. I am about to start the construction of a steam truck which has imperial plans. I am converting the design to metric.
5
Also can not work out how to apply the webs.
Thanks in advance
Steps 1 and 3 can be combined into a single multi-profile sketch if you like.I have got this far, see link
I can not see how to draw the "triangle" (extrude cut) as the disk is actually a cone.
Thanks for your help so far.
https://cad.onshape.com/documents/939a97756eb249052a46905d/w/e9abac8a47150b24bf08c1d8/e/a1585b740f333719febb3b0f
Anyone know a work around? Other than draw it 8 times!
Seems like you're new to 3D CAD. OS has some good tutorials. I would go through those. They're much more explicit.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/900941813cb19e709ef9c759
Here's the finished articles, The larger grey one thanks to Paul.
My main problem was with the circular pattern tool! I did not see the top drop down to change from replicating a part or feature it being above the New, Add remove .... options and also I had not realized that you could specify the axis from a circle (the rim).
Hope this helps someone.
I'm building a 2" scale Steam Traction Engine from imperial plans as well.
What are you building?
Regards
For example if you have your default units set metric, you can still enter "1/8 inch" into a dimension field and OS will work out the conversion. It can also use expressions so you could enter "(3 * 7/8 inch) + 10mm" as a dimension.
I imagine NASA may have found this useful when designing Mars landers...
Regards,
