Drilling holes in front plate after shifting parts in assembly onto their places
Hello all,
I'm designing en electrical appliance. I want to be able to arrange my parts that I fix to the front plate and when I am happy with the placement of the parts I want to drill holes in the front plate that are at the postion of my parts that I attached to it. It would even be better if those holes would move along when I decide to rearrange a part on the surface of the front plate.
How can I achieve this?
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
In Onshape you can just create these parts in part studio and select both part in merge scope of hole. Or if you have some parts imported then use derive to get them into same part studio.
You only need assembly for motion (or larger project).
//rami7
