STL Workbench
I have used STL workbench to repair an STL file, but how do I get that into a part studio?
NeilCooke Moderator, Onshape Employees Posts: 5,895
Hi @jack_pryne mesh import is for reference only (brep operations can only be applied to breps). You can reference any of the points from the mesh to create planes or use in sketches.Senior Director, Technical Services, EMEA5 -
OpenR2 OS Professional Posts: 188 ✭✭✭
A mesh is just a set of points. There is no mathematical surface behind them. Most professional CAD systems have a workbench that gives you the tools to covert the mesh to a surfaces and then to solids.5
I would really like this process to be more robust and even using STL Workbench proved to be ineffectual. Is there an issue with number of faces or file size that may stop the import happening correctly. (I know the 3DS format is limited to 60000 faces).
Any help would be greatly appreciated.
All I have gotten so far is excuses. STL is complicated...ummm OK. STL is new ... I should expect it to be broken...um OK.
So this quarters attempt to use OnShape after a new functionality announcement has failed. I guess I'll try again next quarter.
