Part Rotation Video
Good afternoon,
I'd like to make a video of my part files rotating about an axis. How would I do that?
    While Onshape currently does not have any built in screen recording functions, there are plenty of other PC and Mac applications that will record your screen. From experience, I would suggest trying Camtasia. They offer a free trial that should get you what you need if you only need it for one project. Once you start the screen recording, you can then pan/zoom the Onshape workspace as you desire. I have used this technique to great effect, though it does require a bit of work.
    Onshape, Inc.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,968 image
    If it's a turntable type effect you are after, create an assembly with a mate connector at the origin and assemble your parts to that with a revolute mate, then right click the mate in the tree and select animate.
  • al_griego190al_griego190 Member Posts: 2
    I need a turntable type of video for individual models. I'm using the software on a laptop with a mouse, no spaceball. I was hoping there was something I could do in the software.
    Thanks.
    You can, using the assembly technique I outlined above - but to output video, you will need to use screen capture software. We use Camtasia for our videos.
    Take a look at this document and see if it is what you want:
    https://cad.onshape.com/documents/35b93753f8c84dc6cc401ae7/w/4c0099a82b74b92acf4ffcba/e/8a6bc04567c5e36cf0a6cb9e
    I created a base part that is fixed and the part I wanted to spin. Brought both into an Assembly Studio. Both parts have Mate connectors attached in the Part Studio. I used a Revolute Mate with the two connectors. Right click on the revolute mate in the list and select animate. Start recording your screen with whatever you have to capture the motion.
