New FeatureScript: Thread Creator
Hi, everyone:
It has been a while, but I've been busily working on a new feature for everyone to try.
I'm proud to release ThreadCreator Version 1.0, featuring:
You can find the document here
And as always you can find our other features on the store at http://store.parametricparts.com
Enjoy!
- Thread Types: ANSI, ISO, ACME, Square, and DIN 103 ( ISO Trapezoidal)
- Internal and External Threads
- Multi-start threads for lead screws
- Left/Right handed threads
- Thread lead-in to simulate threads created by taps and dies
- Optional, configurable thread start taper
- Configurable threaded length, lead-in
- Intelligent feature naming ( tries to guess a 'nicely formatted' name for your thread )
<a href="https://cad.onshape.com/documents/6b640a407d78066bd5e41c7a/w/4693805578a72f40ebfb4ea3/e/7886aa5aee640497f4eb6265">https://cad.onshape.com/documents/6b640a407d78066bd5e41c7a/w/4693805578a72f40ebfb4ea3/e/7886aa5aee640497f4eb6265</a>
Enjoy!
15
could be very usefull for 3d printed parts.
Following observations:
I will look into the boundary issue with d=1.0mm
Yes, I think you are right About the rounded bottom. I will fix that also
The nut doesn't show any thread, the thread on the bolt is somehow upside down (the taper is placed in the middle of the bolt) looks like some problem with orientation of the planes.
I'm sorry for a lower-than-I-would-like initial stab at this, but after a complete re-work, version 2.0 is available!
Fixes in this version include:
- Thread profiles are now correct-- including the internal radii
- The feature now updates correctly when you change the diameter
- Fixed bug where sometimes the threads were not working ( this was due to some bad assumptions about cylinder coordinate systems )
- Improved performance
- Fixed issue where sometimes material would be removed when it should not
- Fixed issue with lead-in length with multiple starts.
Thanks @lutz_niggl @neil_cooke048 for the testing!Please let me know of additional issues!
https://cad.onshape.com/documents/6b640a407d78066bd5e41c7a/w/4693805578a72f40ebfb4ea3/e/f8aea9e5c33e02eab0854a4f
yep, the threads finally mate:
A 1/2", 8-start ACME leadscrew:
I've posted a new version-- please get the latest.
Thanks go to @henry_feldman for finding a couple of more issues when creating some nuts.
https://cad.onshape.com/documents/6b640a407d78066bd5e41c7a/w/4693805578a72f40ebfb4ea3/e/c953720c264ce001f1a82dc1
Yes, i noticed that too. Unfortunately, I cannot seem to solve it-- it appears to be an onshape limitation that the feature name is not re-evaluated after the feature is re-created. I'll post an issue though to see if there is a solution...
Great tool, thanks for sharing!
Any plans to include threading to conical faces?
Why is this not in the App store?
Unless something has changed that i'm not aware of, the app store only contains apps, but this is 'just a featurescript'. OnShape has not provided a Featurescript store, which is quite unfortunate for chaps like me who are trying to sell them....
@luis_felipe_morales
Sorry I didnt see your question from back in November-- no plans at the moment to handle conical faces. Just out of curiosity, what's the use case? are you trying to make pipe threads, or ? I'm not sure i understand how conical threads work.... Is there an applicable spec?
Guess I was thinking the apps in the OS store where just featurescripts. I did not realize that they where two different things. Thanks
The start taper distance is missing on my end...also when i check the box to taper, it reverts me back to a cylinder.
Sorry to hear you are having problems. Can you please share a document with me that demonstrates the problem? I'm unable to duplicate it in some very basic tests.
I will not have time to look into this in the next few days, but i'll add it to my list to research....
I think that the geometry is degenerating with the taper and the 0.083 pitch. not sure why really.
as a work around, you might need to add the taper yourself.
Because in some print's the threads will not fit together, the print pressure increases the thickness of thread parts.
