Is there a way to perform a batch Remove from Share?
brian_bradybrian_brady Member, Developers Posts: 505 EDU
So I am using OS to teach a solid modeling class. It is working great (less some minor glitches) and the students love Onshape. As of this moment, I have upward of 500 documents that have been shared with me and I've graded. Up to this point, I've labeled them by assignment name and either on-time or late when I see them show up in my Shared with Me documents. After grading and adding comments to a document, I have removed the assignment and on-time or late label and added a graded label. At some point, I want to remove myself from all of the Shares of graded documents. Is there, or can there be, a way to batch Remove from Share? I would think you could either shift or control click on document names to select several and right click to bring up a contextual menu. The only item in the menu is Labels. Am I missing some other workflow that would do this?
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @brian_brady Have you tried adding your students to a team and just sharing with the team?  Then you can just remove the team from the share.
    Lou,
    I am not sure how or if that would work for individual student work where they each share their documents with just me and not the entire class.
  • fethiofethio Member Posts: 2 EDU
    I am having the exact same problem. It is not possible to unshare a group of selected documents. The shared folder is a mess.
  • rbaekrbaek Moderator, Onshape Employees, Developers Posts: 77 image
    Lou,
    They can still share the documents individually with just you; creating a document whilst in a team does not automatically share it with everyone within the team.
