How do I import different versions of a part in an assembly to view side by side.
This is a typical client/team review situation. Perhaps there is a different approach but I can't see it.
Narayan_K Member Posts: 379 ✭✭✭
@ MBCdesign01, You can't insert a part from old version of active document since you have working in new version and only latest parts are available.
You can insert part from any version of other documents
6 -
bradley_sauln Moderator, Onshape Employees, Developers Posts: 373
As @Narayan_K stated, the best course of action is to start a new document (call it 'Master Assembly Doc') and from there you can take advantage of our linked documents: https://cad.onshape.com/help/#linked-documents.htm?Highlight=linked5 -
NeilCooke Moderator, Onshape Employees Posts: 5,875
You can also use the compare tool between different versions in the same document.Senior Director, Technical Services, EMEA5
Twitter: @bradleysauln
thank you for this, I had worked out something similar. I had hoped to be able to contain an entire project within one document but the only way of having a 'assembly of versions' is to have a separate assembly document.
I have a separate assembly that has snap-shots versions. "Crescent Moon- review assembly" if you want to check it out (I don't know how to link yet)
Fortunately I can import this 'review assembly' into the original document as another assembly tab and it will update as I add move versions to the review assembly (but I need to make a new version in the review assembly). "Bowl- Crescent Moon 01" if you want to check it out.
Many thanks.
Michael
