How to make a simple mate between 2 rods and a support?
![trenton_carr](https://cad.onshape.com/images/placeholder-user.png)
Hi
I'm trying to mate 2 holes in a support bar to 2 rods but it refuses to mate.
I've made revolute mate to the 1st rod and after that I cannot get any other mate to work to match up the 2nd rod.
Assembly works fine in SW and Creo. The shaft is not connected in any way.
Hole and rod centres are exact.
Any assistance please?
Thanks.
![Image: https://dl.dropboxusercontent.com/u/18574055/AWS/nema17.PNG](https://dl.dropboxusercontent.com/u/18574055/AWS/nema17.PNG)
Thanks.
brian_brady Member, Developers Posts: 505 EDU
Could this not have been assembled with a single Fasten mate and an angular offset of 45˚?5
Twitter: @bradleysauln
I cannot seem to find the reason.
If sharing is not an option you can have a look here: https://cad.onshape.com/documents/162727ed93bbb391c1a00286/w/bea92ea5a9b177b871e64254/e/3b3d41d0cd19f0609e611aa7
https://cad.onshape.com/documents/580793fe106cdf112af16d66/w/00444d4baa4cef48f38769aa/e/53eb9c35f72a9d258dad426c
@michael3424 Yes perfectly equal dimensionally. Assembles fine in SW and creo.
To check this I redesigned the support bar with the correct distance (sqrt(2)*31mm). This bar can then be mated to the rods without any issue. The red bar is the new one, the gray is the original bar.
Here the corresponding document:
https://cad.onshape.com/documents/5807ed1a26b0d21143965d65/w/6a102689003bc09d6c2247e6/e/e0d10fe051caea25d2a7b568
I've tried to find the root of the problem so had a look at the source file in Creo.
Accurate to 4 decimal places, I can only assume then that a rounding error happens either during export to parasolid or importing from parasolid.
Either way I cannot spent time remodelling parts that should fit.
Thank you for your help once more.
