How to use Onshape drawing to export to Inkscape to ultimately laser-cut parts?
jordi_medellin
Member Posts: 19 ✭
Hi, I am trying to use onshape to make the drawings (since it's easier) so I can then laser-cute parts. I have inkscape to make the drawings into a PDF file, but I right-click on the drawing, export it as .dxf file, then when I try loading it to inkscape, it doesn't appear.
Can someone please help me on this or suggest easier ways to laser-cut from onshape drawings?
Thank you,
Thank you,
jordi_medellin
Member Posts: 19 ✭
I see, not positive if the software accepts DXF, I will check on that. For laser cutting, I draw it on inkscape and put the lines very thin (0.0001 inch) in red color so the software reads it. Then, I export it as a PDF with the dimensions as it is printed on a PDF file.
Thank you5
Thank you for your response
Thank you
