Creating datums in drawing, when there are no reference elements of value?
lloyd_snell
Member Posts: 26 PRO
I have created a part that has no external features for establishing a datum (B) in a top view. I have found no way to bring the part datums into the drawing, which seems like that should be an absolute. Seriously, how do you transfer design intent with out reference to the model datums? Hidden lines are not selectable in the drawing as far as I can tell. Referencing the datum (B) on the reference view (Front view) for dimension targets does not work. Therefore, I have no means to identify/define a datum and correctly dimension a part view. Any ideas for the work around?
NeilCooke
Moderator, Onshape Employees Posts: 5,933
I think I need a picture - not sure what you mean by "features on the top"Senior Director, Technical Services, EMEA5
