Extruding not working
jordi_medellin
Member Posts: 19 ✭
Hi, I am having trouble extruding these links in the gripper part. I am pretty sure it is all bounded, but for some reason not working, not even a circle that I tried on that sketch. Here is the link to the part:
https://cad.onshape.com/documents/8248edbfee5a39d329838679/w/5bb0bce345ae5afbefd1afc4/e/b621482d14ab530d7922ecf8
Thank you!
Thank you!
NeilCooke
Moderator, Onshape Employees Posts: 5,926
It's because your sketches weren't closed - they should have a shaded face if they are good to extrude. I couldn't work out where you went wrong, so I just re-sketched the links using the slot command for the outer edges and "use" for the holes.
https://cad.onshape.com/documents/5824465732f84011059becc3/w/f8374698ddcfec9694923597/e/d071f6349a613222d78d12fb
Senior Director, Technical Services, EMEA5 -
NeilCooke
@Narayan_K looks that way, but I bet if you tried to reproduce it any other sketch you wouldn't be able to!
