Group Mate vs. Fastened
ethan_1
Member Posts: 17 EDU
Does anyone notice any difference between using a group or mate, such as performance. I personally when mating, especially repetitive things like fasteners, mate one fastener with a fastened mate, replicate it to all holes, group all together, delete the fastened maters. I find this keep things a bit cleaner.
Anyone have thoughts on this?
Jason_S
Moderator, Onshape Employees, Developers Posts: 225
Groups are not mates. Groups are just a way to move a bunch of entities relative to each other without having to carefully select all of the entities every time. If your entities were never moving and your design was never changing then it doesn't really matter.
That being said, if you were to change the spacing of holes on a plate, the Fasten mates would respect these changes since each entity has a Mate connector associated with it.
If you were to delete all but one of the mates and just use a Group, the entities would not properly handle this change.
Hope this helps!
JasonSupport & QA7
Hope this helps!
Jason
