cant find how to use mm instead of inches
frits_sluijter
Member Posts: 1 ✭
cant find how to use mm instead of inches.
it would stand by the properties
3dcad
Member, OS Professional, Mentor Posts: 2,482 PRO
you can change this per document using hamburger menu > workspace units or you can set default units from the menu behind your name > manage account > preferences
and you can also mix unit simply by writing 25mm or 1" as value
//rami6
