How do I get the FeatureScript Beams to recognize the new profiles that I creat?
I made a copy of the Beams script (named it FeatureScript ModifledBeams), Added the profile for 1" X 1" to the profile list, changed the "beamProfileTable" constant to "beamProfileTableMod" in both the beam profile and beam feature tabs.  When I load the ModifledBeams into the document it does not show the 1X1.  If I open the Beams from the Parts Studio it does not have the 1X1 listed.  How do I get the Beam feature side to recognize the modified table?  By the way the 2X4 that was created in the Webinar does not show up either.  As you might have guessed I am not a programmer.  TIA Jerry
    Hi Jerry, make sure you are referencing the correct script. Please see the last comment here: https://forum.onshape.com/discussion/4902/weldments-in-onshape#latest
