Hollow Settings (hollowing and extrusion)
tom_mort
Member Posts: 18 ✭✭
I have a rectangular extrusion and want to hollow it. I'm trying to figure out the settings on the hollow tool control.
I need specific inside dimensions and I see where I can set the thickness of the walls and I read that I can toggle between having the wall thicknesses subtracted or added to the original dimensions of the triangle.
I don't recall now where or what this toggle was, but, I think it was on arrow. I don't really see any changes on my drawing or a way to dispaly what the inside dimensions actually turned out to be.
Can someone clarify this a little?
TIA
TIA
If you cant, try modeling the internal volume of your part and use a Boolean subtract. Or use the Transform -> Scale uniformly option and Boolean the results as desired.
Does the setting above mean if I set my extrusion to have dimensions of x + 2*2.5 by y + 2*2.5 that the inside dimensions of the shell will be x by y?
Is there some way to show a view of the part where all the dimensions are automatically labeled a visible?
PS - I don't see a way to set up this post to have email notification that there has been a reply???
