Boolean operation
michail_brazias
Member Posts: 1 ✭
i want to design a rectangle, then import an .stp file of an aluminum profile.....in order to make a cut operation thus create a pocket on my rectangle to the exact dimensions of the aluminum profile. Is this possible,because till now ,no success.
NeilCooke
Moderator, Onshape Employees Posts: 5,985
As long as the parts are intersecting you can use Boolean subtract.Senior Director, Technical Services, EMEA5
