Pro tip assembly part orientation
Ben_Ben_ OS Professional, Mentor, Developers Posts: 304 PRO
So I want to have my models square to the world. In an assembly this can be a challenge. So my tip is to insert a part and fix it (maybe make a dummy cube), then reference that part to orient one part by using a fasten mate. Fix the part you have just moved, delete the mate and then unfix and delete the dummy part or unfix the original fixed part. Delete the dummy if necessary and voila!
https://drive.google.com/file/d/0B2jg86-MLAyFZll5Yl9hODkyUVU/edit?usp=sharing
  • andy_morrisandy_morris Moderator, Onshape Employees Posts: 87 image
    Awesome tip Ben!
    I presume that you would prefer to have some reference geometry to mate to instead?
    If so, what types would you like?
    Andy Morris / Head of Product Design / Onshape, Inc.
    Planes, origin, and ability to make axis lines would be helpful
  • kevin_quigleykevin_quigley Member Posts: 306 ✭✭✭
    Mate to axes lines, mate to points....or mate to virtual or inferred planes/axes, does anyone do that?
    edited September 2014
    I do that all the time in SolidWorks! I much prefer mating reference geometry over mating actual geometry. If the face definition changes -for whatever reason- the mating reference for that face will blow up. Mating reference geometry is also more robust for revisions of parts that exist in many, many different assemblies. For bottom-up design, mating reference geometry can be a life saver...
    Aligning origins is also a good thing for master modeling techniques.
    This is all true for the strictly parametric world. In IronCAD I couldn't care less about mating conditions.
    Dries
This discussion has been closed.
