How do I create a pattern of normal square holes in a cylinder along a helix path?
klaus_graefensteinerklaus_graefensteiner Member Posts: 3
edited December 2016 in Community Support
I would like to create a circular stair case and was wondering how I add the steps that go up and around the center post.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    Please take a look at the curve driven pattern feature here: onshape.com/featurescript
    it has an example of a spiral staircase.
  • klaus_graefensteinerklaus_graefensteiner Member Posts: 3
    Thanks for the pointer. I'll have a look.
    I tried it out. Works like a charm. Thanks again.
  • EvanReeseEvanReese Member, Mentor Posts: 2,693 PRO
    I see you've already got an elegant solution going on with the curve pattern. That's probably what I'd use too, but your question made me think of another way to do it with only native features using variables. check it out.
    @evan_reese  This sounds interesting but Unable to link to your document; was it removed?
    www.accuratepattern.com
    @bruce_williams
    Not sure what the deal is. I may have updated the document name, which might mess with the link. Try this link.
    It's more of a learner than something I'd apply in a real part, but hey, still interesting
    Curve pattern is now a built-in feature
