Turning a 2D cross section into a 3D drawing
Hello
Looking for some help. I am a cable draughtsperson. I draw out cross sections of cables all day but was wondering if there is away using Onshape to convert them into a 3D drawing. There doesn't have to be twists or anything. I just need help designing it as I have never really used any 3D drawing packages before. It would be good if I could show a bit of each i.e. the copper, then the insulation, then the sheath material. Like in a layer I guess is the best way to describe it. Any help would be much appreciated.
Thanks in advance.
Thanks in advance.
bruce_williams Member, Developers Posts: 842 EDU
Onshape should be good for that. You could even do renderings with a partner package. Below is a quick model of what I think you describe; see https://cad.onshape.com/documents/7d99456e6fb93b2e778d2214/w/d6a7bcc7df9f93ffb712287c/e/b536b9698957ce2dd5fe2152
If you need help starting, I suggest the Onshape videos. see - https://www.onshape.com/learn/cad-training
www.accuratepattern.com5
https://cad.onshape.com/documents/5786b9cce4b0e6bf978a8b9c/w/2af807e3cd318f41a0f73479/e/65a90b7e27f8a1a30d546b93
