How to trim Beams between two cylindrical pipe parts?
frederick_lai383
Member Posts: 2 EDU
I was trying to trim Beams between two cylindrical pipe parts, it does not allow Planar faces to trim to. I tried Parts to trim to. Instead of trimming at the joints of the two pipes, the pipe to be trimmed disappeared. Can anyone help? Thanks.
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,417If it is a very short pipe then it may be getting confused which portion of the pipe to remove. If that is not the case I would appreciate it if you could share the doc with me so I can take a look.
You can either increase the length of the edge used for the pipe on the side you want to keep or do a manual Boolean subtract after the feature is complete. I was considering adding a tolerance field to the UI to mitigate these scenarios.Senior Director, Technical Services, EMEAI5
It doesn't always do the same thing. Sometime it extends the pipe to the ID of the pipe I'm selecting (the red and blue pipes), or it slices the pipe and makes two pieces but doesn't extend past my construction line (yellow), or it cuts the pipe right where I want it and doesn't make a 2nd piece (small gray).
The beam script is a awesome feature.
