Moving a document to another document
Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 267 ✭✭✭
edited December 2016 in Community Support
I'm trying to move/integrate all tabs of a document (in)to anorther document.
Unfortunately I don't succeed. Moving is possible, except a random one of them. He, and so the document, remains. So the whole document cannot be moved.
Is this not possible or is there a way?
    www.accuratepattern.com
  • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 267 ✭✭✭
     Bruce, thank you for this trick.
    It's a pitty that one has to use this workaround.
    In my opinion it should be better when all tabs of a document are selected for moving OS asks for acceptence and then removing the (empty) document after the moving of the tabs.
    Beside that, I have to do some extra work in the target document Kamermeubels. See the text in the attachment below at the red couch.
    Is that extra work correct or am I doing something wrong?
  • raj_Onshaperaj_Onshape Onshape Employees Posts: 111 image
    If you want to move all tabs you can simply do a 'Copy workspace' which creates a copy of the original document. Can you share what you are planning to achieve by moving all tabs ?
    @ptrajkumar
    For example you have shared document 'teamwork' and you wan't to test something before putting it out to the team. If succeed you then move all tabs from 'private test' to 'teamwork'. So it's not a copy but combining of docs.
    @ptrajkumar
    (a) I might design a widget in a new doc and later decide that I want to be able to easily reuse it, so I'll move it into my "common components" doc so I have an easy to remember place to derive from.  To keep things clean I wish to move it, not copy it so I don't end up with orphaned off copies potentially at different revisions.
    (b) Building on that, derive (as it stands today) just gives a big long list, so to make things easier to find I have a several "common components" docs, one for housings, one for hardware etc.  Once derive has a few more search / filter / tag functions I'll want to combine all the "common" docs into one.
    Cheers,
