Creating variants from one part
Hello,
I created a 'euro container' (plastic box) with 400x300x120 mm as part.
For an assembly I need this part in many different sizes. I tried to solve this with branches and versions but in the assembly (after upade) I get all boxes in one size.
How is the best practice to solve this with one part?
Best regards
Ralf
Best regards
Ralf
I think that the easiest way to do this would be to set the dimensions you want and save a version. Rinse and repeat this until you have a version saved for every set of dimensions that you need.
You can then switch to your assembly and follow the steps outlined here under INSERTING A VERSION (ASSEMBLIES) to insert one or many instances of your part from each of those versions.
Best,
Mike
This is perfect example where we need configurations / variants - I hope this feature will be released soon.
