Extrude a mostly mirrored sketch doesn't work?
nocry3nocry3 Member Posts: 28 ✭✭
Hello,
I have created a sketch for an aluminum system profile. 1/8 is drawn (meassured part) and the rest is mirrored. Unfortunately, I can not create extrusion from the sketch.
Only why is not clear to me.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,859
    There must be a gap in your profile somewhere - if the area is shaded then it is good for extruding. A trick to find the gap is to draw a horizontal (or vertical) line through the sketch and drag it up and down to see which areas of the profile are shaded or not.
  • nocry3nocry3 Member Posts: 28 ✭✭
    Great tip. But I can move the line arbitrarily and all partial amounts are represented as gray area. Only the whole profile not. Is this perhaps a bug?
    Not a bug - keep searching. You could also show constraints (in the sketch dialog) to see if there is a coincident constraint at each vertex.
    @ralf, Can you share your document link with us so we can look into that issue.
    I think I've encircled the error, but I do not understand it. It seems that the point in the rectangle is the problem. But why? All the other mirrored points are working?
    edited January 2017
    Thanks for your help. My mistake but hard to find :-)
