Extrude a mostly mirrored sketch doesn't work?
Hello,
I have created a sketch for an aluminum system profile. 1/8 is drawn (meassured part) and the rest is mirrored. Unfortunately, I can not create extrusion from the sketch. Only why is not clear to me.
NeilCooke Moderator, Onshape Employees Posts: 5,886
That is a strange one - zoom into the area marked red, there is a gap. The vertices marked green have a concentric constraint? You should be using coincident. Try deleting your mirrored profiles and turning your construction lines back to normal ones (so your initial profile is shaded) then mirror those.Senior Director, Technical Services, EMEA5
https://cad.onshape.com/documents/5169eb681e6288e1d4eae477/w/6b043fc5f82fc3ca56cb21ae/e/6c1ac6c59892d91c0c9d2801
After closing, you can extrude that.
