Pattern tools lag... Is that my machine or Onshape fault?
linas_dungveckis
Member Posts: 4 ✭
Hi,
I made wire mesh with linear pattern tool, it regenerates, but it takes few minutes to regenerate after every change i make...
The same is happening with face pattern tool.
When i supress linear and face pattern features, Onshape runs fast again.
Anybody experience the same?
Thanks!
Win 8, Chrome, 2.2 Ghz, 4 gb RAM, dedicated video memory 128 mb, shared - 2Gb.
Thanks!
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,248
Can you please post a link to your document so that someone can take a look? Depending on what changes you're making and the graphical complexity of the scene, some slowness could be "expected" or "unexpected". For example, when you change a pattern instance count, it's expected that the pattern will have to take a bit of time regenerating (depending on the pattern complexity), but if you add a fillet after, say, a face pattern, if that's slow, that's likely a bug on our side.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc1
https://cad.onshape.com/check
ilya_baran, this is exactly when i am waiting (For example, when you change a pattern instance count, it's expected that the pattern will have to take a bit of time regenerating
And here is my document link.
