Can I create different assembly "versions" in one document?
Tony_C_Tony_C_ Member Posts: 280 PRO
Not sure if this is possible and if it's not I hope it's in the works as an update.
Here's a simple explanation of what I'm trying to do and can't seem to figure out how to do it.
In one document I have valves of different sizes, 2,3,4,6,8, etc... and also the valve handles, each are parts.  I make an assembly, one valve, one valve handle.
What I'd like to be able to do is have the ability, when inserting (linking) into another document, to set differing assembly "versions" when inserted. Basically, version 1=valve handle open, version 2=valve handle closed.   Hope that makes sense.
    edited January 2017
    @viru
    thanks for the response.  I'll have to play around with it a bit more and maybe share a file to show what I'm exactly talking about.
    I think I got it.  It's just going to take a lot of planning and forethought in order to keep things in line.
    3dcad said:
    Actual function for this purpose would be assembly configurations which is not available yet.
    But as Viru pointed out, it is possible to use versions for this - but you need to ignore the prompt for newer versions available.
    I think it would be much easier to have that function rather than using the document versioning.  This way "works" but I can see it getting very messy.
    @tony_castongia
    Yep and versions are static ie. once created you can't edit them. Use feedback and let Onshape know that you (too) need part + assembly configurations, it will make it higher priority and you get noticed when implemented.
    Playing around with this a bit more and I've noticed that assemblies act differently than my previous CAD program, GeoMagic.
    The mate connectors in OS transfer into the linked child documents and are still free moving. Not something I was expecting. I thought an assembly would act like I solid part and be static when inserted into another assembly in another document.   This is nice because I can just make the valve handles a cylinder mate with 0 Z movement and, if needed, set a new mate in the child assembly.
    No more 'making flexible' to keep motion in higher level assembly.
    I too come from Alibre / Geomagic and I don't miss anything else than configurations + parameter lists. I hope Onshape will have something even better in that area too in near future..
