High Resolution Monitors
andrew_huffmaster
Member Posts: 1 ✭
Hello - I am using a 4K monitor and would like to be able to use Onshape at full resolution without micro icons. Any way to scale the icons inside Onshape?
Andrew Huffmaster
Andrew Huffmaster
OptionsJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646Additionally to avoid blurriness when adjusting the zoom level you should make sure to turn on "Match pixel density" in your account settings. To do this, do the following:
- Get into the Manage Account pane by clicking your name in the top right corner of Onshape, then clicking "Manage account"
- Click "Preferences" in the navigation pane on the left
- Scroll down to "Environment profile settings"
- Click "Create profile"
- Name the profile "4K" or similar
- Change the "Match pixel density" option to "On"
- Click "Save profile settings"
Hope this helps!Jake Rosenfeld - Modeling Team6
I tried the Ctl-Scrolling mentioned by @mahir and it either seems to zoom the whole page or just zoom the graphics view with no change to resolution.
I am on a Dell XPS 15 with the 4K screen.
Ideas?
Thanks,
Cliff
Instead of Ctrl-scroll you can try Crtl+ and Ctrl- (Control plus or Control minus) to zoom the UI. Ctrl-0 will return the page to its default zoom level. What browser are you using? This should work on at least Chrome and Firefox.
Jake
The "Onshape (default)" profile turns pixel density matching on for Mac (to correct for some retina display issues), but off for Windows.Hope this helps!
Thanks a ton. The pixel density setting did it. It looks great now. You might want to make this the default setting for Windows now too. The Windows hardware manufacturers are offering bunches of high pixel monitors now to compete with the Retina displays from Mac.
What prompted me to look for the thread was spotting a 45" diag. 4K Phillips monitor on display at a MicroTech store for $490. It was attached to a gaming system with a Nvidia 2080 Ti GPU so I was really disappointed when OnShape Drawings looked like crap on it. Not knowing about adjusting pixel density made me think it was Onshape's fault. Now, I'm going back to look at it again.
The default Onshape profile has Match Pixel Density set to automatic, and is greyed out. I had to create a custom profile to be able to force it on. So far it works. Considering the default setting is automatic, something doesn't work correctly. It would be certainly interesting to look into this eventually for other people.
Thanks for looking into this.
