API - download a translated file
shawn_dorseyshawn_dorsey OS Professional, Developers Posts: 4 PRO
I have executed the following API call:
"Create translation from upload "
So I now have the following information:
documentId
workspaceId
resultElementIds
the state is "DONE".  How do I download the translated version?  I can do it through the UI which seems to hit an undocumented endpoint
cad.onshape.com/api/elements/download/:did/:eid?workspaceId=:wid
However if I try to access that endpoint I get a 403.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    @shawn_dorsey You can do this:
    https://cad.onshape.com/api/documents/d/:did/[wv]/:wv/e/:eid/export
    The response of this is a file. (I believe it will redirect with a 307 redirect to download).  In your case the done response usually will return a href to link to download.  The above endpoint does this in one shot.
