Adding a Centerline to a Hidden Hole / C-Bore on a Drawing
in Drawings
So, I figured this would be pretty simple to do but I'm stumped as to how to do this.
I'm trying to add centerlines to the four hole / counterbored hole features on the below part. It will not be necessary to dimension to these, but the hidden lines should be there per good drawing practice.
However, when I select the "Line to line centerline" tool, it won't let me select the hidden lines. I got the centerline at the middle of my part using the two-point centerline and the midpoint snaps. How can I add the other lines without guessing at their locations?
Till time please refer below video workaround (By creating section view) as suggested by @PeteYodis
Thanks, I do know that I can add this via a section view. I ended up not needing one, and the centerlines don't really have to be present.
