Assembly view - center of object is offset when a extruded text is included
ivan_centes
Member Posts: 4 ✭
Hi,
I'm new with Onshape and recently I've run into a weird problem.
When in assembly mode, I want to create a mate (in my case a Slider) so that the center points of my 2 objects are linked. When the object has no extruded text on it, the center point is right where it should be. But when I add the extruded text, the center point is moved the opposite way where the text is. See the screenshot, where text is in the lower/right part and center point is offset to the top/left side:
http://bit.ly/onshape-center-screenshot
The size of the offset is linked the the extruded text also. When the text is close to the objects center, the center point is close too. The farther from the center the text is, the bigger the offset.
I prepared a test onshape document: http://bit.ly/onshape-center-offset
Am I missing something? Or is this a bug in Onshape?
NeilCooke
Moderator, Onshape Employees Posts: 5,948
@ivan_centes the automatic mate connectors that appear when you add a mate are positioned at the end and mid points of edges and the centroid of a face. When you add the text you are moving the centroid, so the mate connector also moves. If you want the center of the face, create a mate connector on the part in the Part Studio before you add the text.
Senior Director, Technical Services, EMEA6
