Switch the "LEFT" and "RIGHT" labels on the view cube?
For things like car design, by default in onshape the right side of the car won't be called right unless the front is the back. Is there a way to swap this so the left and right is oriented to the front and back as if you are inside the car/part instead of looking at it?
shashank_aarya Member Posts: 265 ✭✭✭
You can use "Named view option" which is available when you click on smaller cube near to view cube. It works as shown below
5 -
Sunkmail Member Posts: 20 ✭✭✭
shashank_aarya said:Currently named view in drawing is not available but I am sure that it could be one of the priority defined in future developments. Hope it would come earliest! <a href="http://forum.onshape.com/discussion/2604/drawing-view-uses-named-views" title="Link: http://forum.onshape.com/discussion/2604/drawing-view-uses-named-views">http://forum.onshape.com/discussion/2604/drawing-view-uses-named-views</a><br>
edit - Fixed link5
Twitter: @bradleysauln
edit - Fixed link
