Repeat parts in Assembly
seth_roskoseth_rosko Member Posts: 11 PRO
Hello! Thought someone here might be able to shine a light on something I'm missing.
I'm putting together an assembly which uses multiples of the same part placed in differrent orientations.
(Think of a ladder with cylindrical legs and T-joint crossbars)
The verticle bar/ coupler use a cylindrical mate, and I can place them as needed BUT I am unaware of how to call out distances between parts or how to mirror/ replicate sections that may repeat. There are over 70 instances of the same 2 parts, so I'd like to save time where I can. Admittedly I do not use assemblies in this fashion often so I may just be missing something simple. Any suggestions appreciated!
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,147 PRO
    You should be able to use the linear pattern command, even with multiple groups of parts or is there something else you're trying to achieve that I have missed?
  • seth_roskoseth_rosko Member Posts: 11 PRO
    Thanks Bruce, I think the issue here is I am using OnShape Mobile (on Ipad Pro) where this tool is not available.
