loosing relationships
I created an assembly with many parts and have them all mated but when I try to use this assembly in a larger one some of the parts loose their relationship and I am not able to put them back into place.
Is there something that I have forgotten to do in the process?
jackson_king OS Professional Posts: 80 PRO
If parts are mated in a sub-assembly, then you can't move them individually in the higher level assembly, just the entire sub-assembly can be moved. Make sure that something isn't 'fixed' by accident.5 -
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,142 PRO
The fix doesn't hold on assemblies when inserted into another assembly. I never try to have more than 1 fixed part in an assembly for this reason. I quite often will do an assembly with a group mate and 1 fixed part which locks everything in position.5
