How can I import sheet metal geometry from another CAD platform.
RT_AXIOMRT_AXIOM Member Posts: 18 PRO
I tried importing a simple sheet metal part created with solidworks as a STEP file.  I was unable to convert the file using Onshape's sheet metal tools to make the part useable.  Is this possible to do or am I missing something?
  • lanalana Onshape Employees Posts: 757 image
    @ryan_thivierge
    Currently sheet metal Convert functionality would not recognize bends in imported sheet metal model. You can try removing bends with Delete face functionality and using Start sheet Metal Thicken on flat faces.
