Fillet corners in sheet metal issue
bryan_lagrange
Member, User Group Leader Posts: 950 ✭✭✭✭✭
in General
I am working with the sheet metal module and I came across one issue. The fillet command won't let me radius the corners on my sheet metal model. If I hit the finish sheet metal command then Onshape allows me to radius the corners but this does not propagate to the flat pattern. Am I doing something wrong here to enable fillet in the sheet metal work flow?
Thank you
Thank you
1
Fillet is not currently available in active sheet metal models; we are working to enable this functionality in an upcoming release.
Twitter: @BryanLAGdesign
https://cad.onshape.com/documents/035bc5c3b848b773300148d2/w/629c0e401cfead305fb7897d/e/6781dec4447d291f10a3909a
https://cad.onshape.com/documents/a731a3e88822fe8e488007f1/w/33d482742afd41064e922364/e/98b5a1abd77d05ebaff9037f
